eyan219
printrbot
I am using a printrbot to run simplify 3d. I am using the same settings that I have been for repetier (repetier I can use and print with repetier). I keep getting this error message:
Attempting connection at /dev/cu.usbmodem12341...
Attempting RTS reset and trying again...
Connection failed.
I cannot connect no matter what I try.
Thank You
Eyan
Re: printrbot
Do you have the baud rate set in creator to match your printer?
