Solid angle
Posted: Mon Oct 05, 2015 6:02 am
Hi.
When I use multiple processes for a print and the first process is one layer thick then the two bottom layers have the same angle on the solid bottom. Witch make it a little more fragile than it should be.
A natural thing would be that the program used the same angles that I have specified in "Infill".
Regards Tomas Wallentinus
