flarre
Launch on Debian
Hello,
I just bought Simplify3d yesterday (and wait for my printer tomorrow...) so I installed it and tried to launch... nothing in apps, nothing in terminal...
searched in forum and no result for debian install
had to cd /opt/Simplify3D-3.0.2 and launch ./LauncherScript.sh
so I modified LauncherSript.sh to :
#!/bin/bash
export LD_LIBRARY_PATH=""
cd /opt/Simplify3D-3.0.2/
./Simplify3D
(add the third line : cd /opt/Simplify3D-3.0.2/)
and used alacarte (but menulibre would do the trick as well) to make a launcher for Simplify3D (just add a new element anywhere with any title you like and "/opt/Simplify3D-3.0.2/LaunchScript.sh" in command, you can select the simplify logo by clicking in the left square)
I thought it would be useful to add this topic as I searched for Debian and nothing showed
giantpune
Re: Launch on Debian
Thanks. I had also come across this issue and solution. I submitted it to the support team and hopefully they fix it for a future update. For people with a printer that uses x3g files, I found that Simplify3D on 64bit linux contains a 32bit binary to create the x3g files, and the installer does not ensure all the necessary libraries are installed. It is necessary to install the libc6:i386 package before this binary will run.
sudo apt-get install libc6:i386
