Software bugs to fix please
Posted: Sat Oct 10, 2015 1:07 pm
by studiodyne
***************** BUGS **********************
* BUG : in dual extrusion , the manual generation isn't working for the second color , for example i make manual support for color 1 and manual supports for color 2 , the software make automatic generation and don't want my manual design for the other extruder
*BUG , impossible to make a total pillar in manual support generator when touching bed , it's only possible if you are a little higher ???? BIG BUG
* When concentric solid layer , don't make paralell support , it's unneeded and this will make print in the void !
* BUG of the LAYER DOUBLING !
You have doubled the number of layer by adding a new layer for pillars , dual ex , of ozze shield ,ALL IN THE SAME Z AXIS , so two half layers in one , and the problem is when we select ‘ REDUCE SPEED WHEN TIME IS LESS THEN 15 SECONDS in the cooling tab ‘ , the layer without shield is reduced of speed and the second part is printed 100% speed , and we have two speed alternatively , just because the total layer is divided in half layers … The total layer is more than 15 sec but , just because divided in two half parts , we have two speed for the same Z AXIS or true layer
Re: Software bugs to fix please
Posted: Tue Oct 13, 2015 7:48 pm
by C-line
Agree that the print speed of the ooze shield should not vary from layer to layer due to the interaction with the cooling speed overrides. This results in a LOT of wasted time as the ooze shield is printed too slowly on every other layer.
