I try to print a single model with multiple processses to save print time.
Question 1:
After slicing there is a gap between the processes visible in the preview. This gap is also visible in the print.
It looks like the stop height and the start height are equal when S3D calculates it.
So I tried calculating the exact height myself.
First process height
First layer Height = 180% x Primary layer height 0,150 = 0,27mm
99 layers x Primary layer height (0,150) = 14,85mm
Total for 100 layers = 15,22mm
So the First process stop height = 15,22mm
And the Second process start height = 15,22mm
But using these values still gives a gap in preview and in print. What am i doing wrong?
Question 2:
On of the processes needs a bottom layer for an overhang. But the bottom also gets printed inside the model. I don't expect this because the model is closed. The problem is, the overhang is only a few cm2 but the complete model is almost 100 cm2. So this takes a long time to do a 3 layer bottom surface which i try to save. How can i prevent S3D from making solid bottom layers inside the model?
Any thoughts/tips/tricks are welcome
Rolf
