smartavionics
100% reliable crash when checking duplicated model
Using S3D 3.0.1 on Linux, when I import the attached STL, duplicate the model once so I have two instances of it and then do "Identify Non Manifold Edges", program exits, every time, 100% reliable. If I don't duplicate the model but just have one instance of it, it passes the test and doesn't crash.
arrow-rest-5-base.stl
(79.23 KiB) Downloaded 221 times
Re: 100% reliable crash when checking duplicated model
No faults, works fine. Also with 2 other objects together an just 4 copies from each.
GER
