Hi there.
first, I am new to printing and have 3 print attempts - so I might just do sth. wrong.
anyways...I have setup my brand new assembled M2 running Creator 1.0.4 on win7 (using the makergear config introduced in 1.0.3) and my first print came out awesome. It was the bracelet print that is on the M2 SD card. However, that was sliced before as the card only contains GCODE.
Very impressed by the result I tried a self modelled object. It sliced nicely but when the print started...
...the first layer was properly put down as seen before. After the first outline the first infill layer started and it started to look untidy, but ok. Then the nozzle started to push hot filament along. After some more moves it looked like the nozzle had been LOWERED for the next layer, meaning after layer 1 the M2 tried to print on glass level, instead of Layer2-level. As if the z-orientation flipped mid print.
I also tried another (proven) item from thingiverse (earbud holder). Again, the first layer looks good and upon start of layer 3 (or 2, not sure) the nozzle works its way back down and another emergency power kill saves the glass.
As the prescliced bracelet worked and two items that were sliced in creator did not,I guess here is where to look. Then again...other seem to not share that problem...Please help !!
