Auto lowering bed after print.
Posted: Sun Oct 18, 2015 11:29 pm
by atomickidstudios
In other software I've used the Gcode will automatically tell the bed to lower after the print is completed, so the hot print head doesn't sit on the model. Is there a setting similar to this in Simplify3D?
Re: Auto lowering bed after print.
Posted: Mon Oct 19, 2015 7:41 am
Sure. Just go to the Scripts tab and add one command at the bottom of your Ending Script.
G1 Z999 F3000 ; change Z999 to the maximum Z-height of your printer (for example Z150)
Posted: Tue Oct 20, 2015 4:54 pm
by Nightram
I think a G90 needs to go in as well as it worked too well on mine and went below the maximum level of my bed.
Posted: Wed Oct 21, 2015 6:32 pm
by atomickidstudios
Thank you. After some digging around I discovered the "Scripts" tab.
This is what I ended up using:
;End GCode
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
;G1 E-1 F300 ;retract the filament a bit before lifting the nozzle to release some of the pressure
;G1 Z+0.5 E-5 X-20 Y-20 F12000 ;move Z up a bit and retract filament even more
G1 Z0.2 E-2 F2000 ;move Z up a bit and retract filament even more
G4 P600 ; dwell time of 900 ms
G28 X0 Y0 ;move X/Y to min endstops so the head is out of the way
G91; use relative
G1 Z50 F3000; drop 50mm
M106 S0; turn off fan
M84 ;steppers off
G90 ;absolute positioning
Posted: Tue Mar 01, 2016 3:52 pm
by cooldirtspot
Hey, I came across this post and am having the same problem. I was wondering as a g-code baby if there is anyone out there who might help me resolve the same issue for my Craftbot3D + printer. The specs are here: https://www.3dhubs.com/3d-printers/Craftbot
Basically, the extruder tip sits on top of the print oozing and i wish i could just bring the bed down automatically.
Most advanced achieved:
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M107 ; turn off fan
M84 ; disable motors
Fail:
M107 ; turn off fan
G28 ; home all axes
So far, as advanced as my ending scripts have gotten has been successfully turning off the fans at the end of the print and unsuccessfully ramming my extruder into my print by adding a G28 return to all home axis script.
I think the last post involved some retraction too, so the filament doesn't blob up ontop of the highest point but all this is very new and advanced for me.
Any help would be REALLY appreciated. Thanks in advance!!!
Posted: Wed Mar 02, 2016 6:26 am
Yes, a G28 is a "home all axes" command, so it's going to home your printer to the normal homing location (which for most of us would be very bad if we had a print on the bed).
If you want to lower the bed completely, why don't you just add a single G1 command to move to the max Z position. For example, if your printer's build volume had a Z-height of 120mm, add this command to your ending script:
Code: Select all
G1 Z120 F1800 ; move to Z of 120mm at 1800 mm/min speed
Posted: Mon May 02, 2016 2:55 pm
by serpentineocean
I'm Running a Craftbot+, I use this at the end script to drop the bed.
G0X0Y0Z200 ; GoHome and drop bed
Posted: Tue Aug 23, 2016 8:25 pm
by rpasaustralia
CompoundCarl wrote:Yes, a G28 is a "home all axes" command, so it's going to home your printer to the normal homing location (which for most of us would be very bad if we had a print on the bed).
Code: Select all
Im a newby to Repetier and so when I went to get my first Rep print out I pressed the "home ALL" and the bed went up, jamming the model up against the rails..Im hoping they are not bent! So WARNING on the home All. Fortunately I killed pwr quickly.
