Cutoff
Posted: Mon Oct 19, 2015 10:14 pm
by erniehatt
I have put together the model shown in the image, I have drawn a line across it, I need to cut it off there.
Any ideas how I can achieve this.
I thought that maybe I could stop the print at the appropriate point, what are you views on this.
Re: Cutoff
Posted: Tue Oct 20, 2015 5:29 am
The easy way...work out the height to your cut line and set the print to stop at this height using the settings on the Advanced tab of the settings.
A more complicated way.....use the free version of Netfabb to slice the model into two. (Never done this myself, so can't give simple instructions without trying it myself.)
And a third way....turn the model upside down and lower it so only what you want to print is above the bed. it'll print like that.
Re: Cutoff
Posted: Wed Oct 21, 2015 5:12 pm
by danielhenley
A few different ways:
1) turn it upside down and lower the section you don't want to print below the build plate
2) set it to stop printing at a certain height in the process setup
3) use 3d software to break the model up (meshmixer can do this).
3 is the best solution as it will give you a filled in edge where you cut it off.
Re: Cutoff
Posted: Wed Oct 21, 2015 6:18 pm
by erniehatt
Thanks Doug, I will take a close look at all those suggestions.
