Rostock max v2 calibration issue
Posted: Wed Oct 21, 2015 12:02 am
by skidoosnopro
So I am having a difficult time finding the horizontal adjustment in the calibration settings . I have the x y and z position height nozzle height good but can't find where I adjust the center height like it says in the restock calibration instructions. Any help please .
Re: Rostock max v2 calibration issue
Posted: Sat Oct 31, 2015 11:23 am
by predawnsky
im having the same problem
Posted: Sun Nov 01, 2015 9:58 am
by JoeJ
You just have to edit the z-height in the firmware. It's usually in the configuration.h file and called something like Z_MAX_LENGTH
Posted: Sun Nov 01, 2015 10:20 pm
by KAS
By using the macro's in the instruction manual. Follow the flow chart in the manual as it can take a few tries to get it calibrated.
Calibrate X/Y/Z macro to be the same distance as each other by adjusting the end-stop screws. Then adjust the horizontal radius until the outside X/Y/Z macro's are the same distance off the bed as the center macro. Keep in mind that the center of the bed will "not" change when you modify the horizontal radius. Only the outside locations will change. This corrects any concave or convex motion of your effector.
Once the center & X/Y/Z are the exact same distance off the bed, use the menu on the LCD to set the Z-Height. Make sure you select "home" first.
Also, check out this page as RollieRowland has made huge progress into automated leveling/calibration of the Rostock v2.
http://forum.seemecnc.com/viewtopic.php?f=36&t=8698
