Machine X axis flip setting keeps reset
Posted: Thu Oct 22, 2015 2:17 pm
Hi, I got an annoying problem in Simplify3D which is that the "Flip build table axis" settings keeps resetting to unchecked (in the Tools->Option->Machine config tab).
I have a kossel delta printer with repetier firmware which needs the X axis going to the Right, Y axis away from XY tower line and Z upwards, zero Z being the first layer...
I basically need to go and set this option again and again before every print.
So far I've isolated the following occassions when the reset happens:
1. Restart of application
2. Edit process settings (after I clicked OK, the X axis is reset to unchecked again).
But it seems to happen in more situations which I haven't kept track of.
Please help!, love my Simplify3D setup otherwise, it rocks!
