I'm new here on this forum, and i really hope you guys could help me.
I've made some prints at 0.1mm, they all work fine, except for one problem.
It seems that even though the Z resolution is at 0.1, the xy resolution is way lower, making vertical lines on cilinders, and xy islands on curved objects.
Its a section of a arm, this is the position it was printed, so it will have horizontal lines as expected.
But, with we look at the side of the arm, were is convex, you can see the xy islands that i'm saying.
I have a Sethi 3d Aip, it's a brazilian printer, the guys from the company says the step size of the X and Y motors is 0,0125mm.
So, is there any type of setup that i fix that inside Simplfy3d?
Can this be a configuration issue?
Thanks in advance!
