I'm new to S3D, and am trying to dial in my S3D settings. I've created a simple 20mm x 20mm x 10mm box in 123D Design to try an calibrate and test my system. I've leveled my print bed, but I'm seeing an issue with the edges/sides curving... when the print is finished, the vertical edges are curved. The model is a box, with 90 degree corners, so I wasn't expecting the results that I'm getting.
Here's my setup:
Windows 7 Pro communicating over USB to my printer
Taz4.1 printer (stock, w/no firmware or other hardware modifications)
Printing ABS I purchased from Lulzbot
Before I print, I pre-heat up the bed to 91, and the nozzle to 231, and when I print I have the "wait for temperature control to stabilize before continue" option turned off.
(and fan speed is 0)
For the S3D Process settings, I'm:
- using the default Taz4 process created by S3D
- selected the "auto configure for ABS" and the "auto configure for High" settings
- changed the layer's top and bottom solid layers to 10 each
- changed the number of outline/perimeter shells to 4
- all options in the Additions tab page (skirt, raft, etc...) are off
I thought the issue might be due to be height and bed leveling, so I ran through bed leveling. I also played around with the bed height, but I think I have it dialed in.
Any idea as to what's going on, and how to fix it?
I've played around with the S3D settings, but haven't been able to figure out what the issue is.
The only thing else which comes to mind is that I'm not printing inside an enclosure. There aren't any fans blowing on my printer (the fan on the power supply is directed away from the bed/nozzle). I have everything set up in my attic, and the ambient temperature right now is around 64 F, though I didn't have this kind of problem printing edges with Slic3r and PrintRun.
Thanks for any help,
Jeff
