No Top Solid Layers wanted
Posted: Mon Oct 26, 2015 2:18 am
I was trying to print the 20mm hollow Box from The essential calibration set on Thingiverse:
http://www.thingiverse.com/thing:5573/#files
Infill: 0%
Bottom solid layers: 2
Top solid layers: 0
This should leave the top solid layers away so the cube is open from the top, right?
However. SimplyFy 3D 3.0.2 doesn't do that.
When I also set the bottom solid layers to 0, the bottom solid layers AND the top solid layers disappear, which in this would be correct, but I want bottom solid layers and no top solid layers, which doesn't seem to work for me. I let other people look at this as well and they are encoutering the same issue.
Look like a bug to me?
Regards
Sebastian
Infill: 0%
Top solid layers: 0
Regards
Sebastian
