Very Rough Edges on Robo 3D R1 Plus
Posted: Mon Oct 26, 2015 1:16 pm
by philline
On my prints, as you can see, the sides are coming out extremely rough. The bottom layers are smooth, but when it starts building the sides, it lays out the 2 outside beads smooth, then when it fills in between those beads, it shakes/vibrates and seems to push out the smooth outside beads causing the roughness. The original.stl file looks perfectly smooth. I get the same results with Matter control slicing as I do with Simplify3D. None of the machine parts appear to be loose. Is there any setting in S3D that will correct this.
Re: Very Rough Edges on Robo 3D R1 Plus
Posted: Tue Oct 27, 2015 5:11 am
Looks like either a lot of over-extrusion or a machine issue
