Printer model keeps disappearing
Posted: Tue Oct 27, 2015 9:06 am
by simonBR
Dears,
I've created .STL file with model of print bed for my UM2 printer.
when I import the model via: Tool->Options->Machine->Printer Models->Add->printer_bed.STL everything seems to work great, but when I exit the program (or even sometimes when I prepare the print and then exit the preview) the bed model disappears.
How do I "save" the model to be always visible?
The .STL file is always on the same location.
Thank you!
Re: Printer model keeps disappearing
Posted: Wed Oct 28, 2015 6:02 am
That's probably because many of the profiles have the <printerModelOverride> option enabled, which essentially allows you to automatically switch to a new printer model when you load a new profile. A very neat feature. So you just need to set that up for your profile.
The link below explains how to do it. You essentially just export the profile and add 2 lines to it, save it, and re-import.
Add these lines:
<overridePrinterModels>1</overridePrinterModels>
<printerModelsOverride>C:\Path\To\My\PrintModel.stl</printerModelsOverride>
Link with explanation: viewtopic.php?f=8&t=2356&p=12342#p12342
Posted: Wed Oct 28, 2015 7:54 am
by simonBR
Thank you so much!
Below I quote the full process of setting up custom print bed.
I would also like to add a simple solution for positioning the bed model (this question occurred in the linked topic).
What I did was (in SolidWorks) to create a new coordinate system and positioned it the same way as origin in S3D, then I saved the .stl with the new origin. It imports in S3D perfectly.
You would want to put the file into the folder:
C:\Users\**USERNAME**\AppData\Local\Simplify3D\S3D-Software
Then go into Simplify3D and go to File-->Export FFF Profile. Then open that file up with a text editor.
Find the two lines:
<overridePrinterModels>0</overridePrinterModels>
<printerModelsOverride></printerModelsOverride>
Change those to:
<printerModelsOverride>myPrintModel.stl</printerModelsOverride>
Where myPrintModel.stl would be the name of your file.
Then save it, and go to File-->Import FFF Profile.
Thanks again.
Posted: Sat Mar 11, 2017 10:42 am
by slippyr4
This thread solved the issue for me, but for the benefit of users on a mac, you will need to put your STL in the following directory:
~/Library/Application Support/Simplify3D/
(Open a finder window, then menu "Go" - "Go to folder", then enter the above path in the dialog and click ok.
Posted: Sun Mar 19, 2017 1:01 pm
by cyberreefguru
Are you sure about the Mac path? Looks like I have ~/Library/Application Support/Simplify3D/S3D-Software
-Tom
Posted: Thu Aug 10, 2017 11:16 am
by joealarson
Can fixing this please be made a priority? If we import an STL through the menu all of this should be set and associated with the machine settings automatically.
Posted: Fri Jan 26, 2018 3:37 pm
by walkeraj
I agree; a hack should not be necessary. Fix this, please.
Posted: Fri Feb 09, 2018 3:51 pm
by Boby
Well, 2018 and this is still not fixed. Congratulations!
Also I have problems applying the "hack" on 4.0.1 - could there be a problem with this workaround in 4.0.1?
Posted: Sun Feb 11, 2018 2:40 am
by rrdavis
Works fine for me. You're just editing the profile, so it isn't really a hack.
If you don't want any printer model displayed anytime you use the profile, then just open your profile in a text editor and change these lines
If you DO want a specific printer model to be displayed, then change it to this:
<printerModelsOverride>C:\complete\path\to\model.stl</printerModelsOverride>
They just save and re-import the profile into the software.
