spiderx1
Dual Extrusion Not Supported
So I had to use other in the configuration assistant to setup my MakeIt Pro. I selected dual extruders.
But when I try to run the Dual Extrusion Wizard I get the You do not have any profiles that support dual extrusion through this
wizard, message. When I try to print with just one color it heats and draws a skirt with both extruders.
Should I try to start with a model listed?? Then make the changes and rename.
Re: Dual Extrusion Not Supported
I'd probably suggest starting with a profile for another dual extrusion printer like the leapfrog creatr dual, and then just modifying it to match your settings
