ABS+PVA ooze issues
Posted: Sun Nov 01, 2015 4:22 pm
by streambox
I'm trying to print ABS + PVA support material on Flashforge Creator Pro.
It looks "ooze" wall for ABS part is getting dragged. Not sure if this is retraction or ooze settings.
Any advice on what should I try?
Re: ABS+PVA ooze issues
Posted: Tue Nov 24, 2015 10:36 am
by MichaelHerron
[quote="streambox"]I'm trying to print ABS + PVA support material on Flashforge Creator Pro.
I've not had much luck with this combo either. While it may be possible, most use HIPS for dissolvable ABS supports while PVA is generally used for PLA.
ABS doesn't seem to stick really well to PVA and it prints at a much higher temp. This makes the combo very difficult to manage. I gave up and just use abs supports.
If you can score yourself some d-limonene, give HIPS a go (if you MUST use dissolvable supports).
