Help Inventor Non-Manifold Edges , Self Intersecting surface
Posted: Mon Nov 02, 2015 8:43 am
by SimoneScheggi
Hi ,
can someone help me , I do not know how to avoid that there are errors :
Non-Manifold Edges
in Simplify3D.
I tried to change the design several times but I always get the same result :Non-Manifold Edges Self Intersecting surface
Please Help!! what wrong? (see the attach
Archive.zip
Ring
(2.6 MiB) Downloaded 145 times
Simone
Ps I have attached the file in Inventor and sol
Re: Help Inventor Non-Manifold Edges , Self Intersecting sur
Posted: Tue Nov 03, 2015 5:54 am
by JoeJ
That's because your 3D model isn't a water-tight 3D solid. It has some unconnected surfaces. You need to boolean all the parts together to make sure it is a single water-tight solid.
Someone who uses inventor more can probably provide instructions if you don't know how to do this.
