[BUG] Buildplatform size wrong.
Posted: Mon Nov 02, 2015 11:47 am
I own a delta printer (kossel mini style) and I'm having issues with the platform size.
I choose the default kossel mini configuration and got a standard build platform this is what S3D has as standard values:
Build Volume X: 170
Build Volume Y: 170
Build Volume Z: 240
Origin Offset X: 85
Origin Offset Y: 85
Origin Offset Y: 0
This seems correct to me since the diameter off the platform is 170 mm.
In S3D the displayed platform is 240 mm in diameter, I already found an old bug report for 2.xx in which it was suggested that the inner square of the circle needs to be used. Some one should clarify this and fix the default configs if that is the case or better yet allow inputting a radius for delta printers not x and y values.
Here a picture to clarify in red marked the actual size.
Build Volume X: 170
Build Volume Y: 170
Build Volume Z: 240
Origin Offset X: 85
Origin Offset Y: 85
Origin Offset Y: 0
