[CLOSED] PowerSpec 3d Print Issue
Posted: Wed Nov 04, 2015 12:48 pm
To start off there is no support for my printer so I hope somebody here can give me advice. I appreciate you taking the time to look at this.
I have a PowerSpec 3D from Microcenter which is basically a rebranded Flashforge and it's running Sailfish. Turn your audio down before watching the videos becuase I have some equipment that's pretty loud in the background.
Both prints are the same item on medium defaults with a brim.
First issue:
I'm having a problem with shifting on the X axis. In the video you can see it skipping and hear a hard "click" when it skips and then the print is shifted to the right.
https://youtu.be/DAd7K7eHYgw
For troubleshooting I've tried tightening the belt (it wasn't loose) but the issue is persistent. Watching it print it seems like it's being blocked by something and then skipping but I can't find any blockage. I've also lowered the print speed to a crawl but that doesn't help either. It doesn't always skip in the same spot and might skip as soon as the print starts or an hour in to the print.
Second issue:
This one is really weird. Sometimes my printer just stops printing and reboots. Again, this problem is intermittent and doesn't always happen at the same time.
https://youtu.be/pDMw8T-t1Cw
For troubleshooting I've tried to find something online related to this but haven't found much. Some people have said taking off the bottom panel can help because it sometimes causes a short but that didn't do anything either.
First issue:
Second issue:
