tpra
Supports brim
A feature i'd like to see implemented is a brim under the supports.
It helps a lot to have a thin 1 layer plate under the supports so that they just can't detach from bed while printing.
To do it i just create a thin plate and add it to the bed. Basically it just has the shape of the shadow of the model with a light perfectly on top (sorry if i don't explain this correctly :/ ). But it's a bit boring and it would be very nice to have an automatic option :)
Stefan_Koch
Re: Supports brim
Yes, indeed !
+1
danielhenley
Re: Supports brim
This has been requested a number of times here, it's badly needed.
larsgw
Re: Supports brim
I strongly request this as well.
I'm printing parts on an angle, so there are parts that stick way out past the initial brim. In situations where supports are needed I have to make massive brims around the entire print in order to anchor one or two supports on one side.
Solo supports are often nudged loose, especially when they are single towers that have to go up fairly high. It would be great to have a checkbox in the Brim section that would allow supports to be considered when brims or rafts are calculated.
Some kind of tapered towers would also be great, so they started heavy at the bottom but slim down just before hitting the part.
Even branching supports, like those in Meshmixer would be useful.
KC_703
Re: Supports brim
This would be helpful.
In the meantime, I manually place anchors on the bed where the supports can print on... It can be meticulous, but you can scale the discs or squares in the XY keeping the Z at .5mm.
Anchor - Disc.stl
Scale X & Y, but don't scale Z.
(22.31 KiB) Downloaded 446 times
larsgw
Re: Supports brim
KC_703 wrote:This would be helpful.
Thank you! That's a great idea.
RR4711
Re: Supports brim
+1 from me as well
