linux x64 no GUI after login
Posted: Sun Nov 08, 2015 12:11 pm
by boredpenguin
Install seems to go without issue. After running the program the login window comes up. If i run as root the login window goes away and the process keeps running. If I run as a regular user, the login process stops and a new process is started, but the actual program GUI never appears
Fedora 23 (gnome 3.18) 64 bit
Re: linux x64 no GUI after login
Posted: Mon Nov 09, 2015 5:07 am
by JoeJ
Hmm.. it's working for me. All I had to do is run the commands below
cd /opt/Simplify3D-3.0.2/
sudo ./LaunchScript.sh
Opens just fine with that. If it doesn't work for you, maybe check the crash log in case it is due to a missing dependency or something.
Posted: Mon Nov 09, 2015 2:15 pm
by boredpenguin
I was running ./Simplify3d directly rather than using the LaunchScript.sh
All good now, thanks.
