Raft support not working
Posted: Sun Nov 08, 2015 11:33 pm
by daniel541
Hi, i have my starting print height set ad +1.2mm in the advanced tab under layer modifications. whenever this is activated i loose the function of having rafts or skirts .. why is this and can it be fixed ?? thanks
Re: Raft support not working
Posted: Mon Nov 09, 2015 5:16 am
by JoeJ
I don't believe you can use a raft if you are starting printing in the air. You can only use it if the "start printing at height" feature is disabled.
What are you trying to accomplish by setting the "Start printing at height" option to 1.2mm? If you're trying to account for improper positioning of the bed, then you should be using the global gcode Z-axis offset, not the start printing at height feature.
Posted: Mon Nov 09, 2015 6:24 am
by daniel541
yeah i went in the firmware and just changed it there, much easier !
