select improrted parts to print.
Posted: Wed Nov 11, 2015 9:53 am
by Rebekah_harper
Hiya,
with the tick boxes on the parts list can you make it so that only the ticked parts are printed and the un-ticked are ignored.
In addition to this:
I print with abs which is renowned for adhesion problems and warping. I solved this by extending areas with either a disk or oblong area of 0.3mm thick. by increasing the surface area with a minimal suseptible to warping feature I manage to maintian goo adheasion and minimal to no warping. (at times the feature is holding on for dear life as the part warps)
I also use the oblong as a pilar to large area over hangs. I intorduce this to the over hang down to the bed along with one of my adhesion disks on the base. this gives a good level of control of the warping.
I was wondering if there was the option to have a feature which contains custom .STL files which could be accessed quickly when needed.
either as a seperate window on the left containing regularly used parts and selectable by tick box as per above.
or
as a inset menu. something like INSERT FIXED FEATURE with a sub menu showing all the .STL files I have added.
or
you could just have two default features one a disk the other a bar. so on the left have two buttons one for each. from there each click adds another on the build plate. these do require to be editable by means of the double click and the adjustment window as both need to be resized according to the needs of the part.
many thanks
Becky
