A prob using other filament
Posted: Thu Nov 12, 2015 11:08 am
I had a large roll of PLA from a previous machine. I figured I'd use it up with the M3D.
I also just started using Simplify3D
New new PLA, which is the same size, works great, except the edges curl up an lift. I knew that was a problem with ABS, but not PLA.
I thought maybe it was happening from Simplify3D so I tried a print using just M3D and had the same problem.
The first, smaller part I made with this filament did work and that was with Simplify3D.
So Im assuming it has something to do with the filament and object size.
I looked at the settings that simplify3D uses for the M3D and it was pretty intimidating. i didnt mess with anything there.
Any ideas?
Any ideas?
