Hello,
This may or may not be a common problem. Ever since I have been using Simplify3D on my Taz 5 I have been using a raft. Recently I tried printing on just the heated bed with no luck. Thinking it was the printer I loaded my file into cura to print with no raft and it prints 100% fine with no raft, which leads me to believe it is either a bug or a setting that needs to be changed in Simplify3D.
So far I have reset all the factory settings, tuned the setting and even tried reinstalling Simplify3D, each time having no luck. If someone else has had this problem or has a solution to this problem please let me know. Once again my main issue is printing with no raft on a heated build plate. Very little dots and strands of filament come out if none at all. I have let the print go through a few layers with the same luck. Not enough filament is being extruded, but when printing with a raft all is fine.
Hope someone can help.
Thanks,
Brian
