Courty
Holes being filled during process
Got an issue with a couple of files i'm trying to print.
The STL has various holes through the model ranging from 20mm to a couple of mm
when I try to prepare the file, all the holes get filled with a plug. tried lots of setting changes but don't seem to be able to get it to render properly
Tried the file on Makerbot and Autodesk123 and they render it OK ?!
I tried printing just to make sure its not a bug in the viewer but the plug prints too
Any ideas as i'm seeing this in a few files from the same source
Paul
Electronics SHELF.stl
(428.58 KiB) Downloaded 220 times
Re: Holes being filled during process
There's a bunch of problems with your mesh. Go repair it first: https://modelrepair.azurewebsites.net/
garyl
I have the same hole filling issue but it does it for only one layer. It does it for one layer when the layer is set @ 0.2mm, when printing at 0.1mm layer it does not do it. When I set the layer to 0.3mm it even fills the large holes. There is nothing wrong with the model mesh.
How can you say there is nothing wrong with the mesh? I can literally see holes and isolated surfaces just from looking at it in the software. Both S3D's repair checking tools and Netfabb's both identify many errors with your mesh.
garyl
Sorry I was talking about my own files. There is another thread about the same issue viewtopic.php?f=9&t=3354. When I adjust the layer from 0.2mm to 1.9mm the holes open up again but like I said its only happening on one layer in my model.
