spiderx1
Print Stops at 99%
All files print stops at 99% so it appears that end of print Gcode is never triggered. MAKEiT Pro printer.
Last command is
Sent: G1X108.872Y128.777E27.9114
RECIEVED: OK
SENT:G92 E0
SENT:G1 E-6.0000 F3600
RECIEVED:OK
RECIEVED:OK
RECIEVED:OK
End of print script is:
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
M84 ; disable motors
G91 ; relative positioning
G1 E-2 F9000 ; retract the filament a bit before lifting the nozzle
G1 Z+10 E-10 X-50 Y-50 F{travel_speed} ; move print head and retract
filament
M117 MAKEiT Pro@Done
M84 ;steppers off
G90 ;absolute positioning
M81 ;Turns power off from the printer
rich17950
Re: Print Stops at 99%
This has happened to me on several occasions and I used to give up on the print and start over. I have no Idea why but this is what I do after it stops, In the machine control panel I click the pause button then click resume print. This has worked every time it has stopped. This is only good if there is no mechanical issues with printer ie; clogged nozzle or other issues.
spiderx1
Thanks,
The big issue is if it is an unattended print. The nozzle stays hot and filament oozes onto the print.
Last time I printed via SD card vs USB and it worked.
