Outer layer rectilinear fill angles
Posted: Tue Nov 24, 2015 10:28 pm
How do I set the outer layer rectilinear fill angles? If I change the infill angles it has no effect on the outer layers.
Simplifying the 3D Experience!
https://forum.simplify3d.com/
Fred B wrote:Unfortunately, you can't. I would also like to see a concentric option.
The start angle is already a feature request. I hadn't thought about the end angle...
But, the workaround is to rotate the part (hint, the first angle used for the bottom layer is 45 degrees)
billyd wrote: ... that only fits on the build bed at 45 degrees so I am stuck.
