9beer
How to setting software for Flashforge Finder?
i buy Flashforge Finder and i want to use Simplify3d, anyone know how to setting this program?
thank you
Re: How to setting software for Flashforge Finder?
I attached a profile I have been using. It's really similar to the FlashForge Dreamer. Just export the gcode and then copy to the USB drive for printing on the machine.
PS - I'm not 100% sure about the M132 command in the starting script just yet. Some of the Finder commands seem to have changed. Can you post a gcode file that you've already printed (perhaps from FlashPrint)?? It would be good to compare against what I've been using since I've made a lot of changes to the stock flashprint settings.
Finder.fff
(13.97 KiB) Downloaded 2167 times
el_norman
JoeJ wrote:I attached a profile I have been using. It's really similar to the FlashForge Dreamer. Just export the gcode and then copy to the USB drive for printing on the machine.
The attachment Finder.fff is no longer available
I don't know if anyone is following this thread anymore, but here is the gcode for a 10x10x10 cube that was sliced with Flashprint that was asked for. I had to change the extension because I got a message saying "The extension g is not allowed".
10mm cube.txt
(61.13 KiB) Downloaded 681 times
perohlsson
The Finder.fff profile above works great for my Finder with Flashforge PLA ;)
Thanks for uploading!
Very soon I will try PETG from 3D-Prima.
/Per
