End/ start of layer
Posted: Fri Nov 27, 2015 3:51 pm
by Tttugeman
i am experiencing problems with print quality at the end/start of layers. I have tried numerous ooze control setting and cant figure it out, attatched is a photo of this problem
Re: End/ start of layer
Posted: Fri Nov 27, 2015 4:56 pm
by KiLLiN-TiMe
Someone correct me if I am wrong, but I believe you want to go to the "layer" tab and choose "Use random start points".
That should spread the start points around so they are not all lined up and wont stand out so much.
HTH
KT
Posted: Fri Nov 27, 2015 5:04 pm
by Tttugeman
Hi, i do not want to spread the marks out i want to get rid of them.
My settings are
Retraction distance 4.2
Extra restart -0.2
Coast at end .08
Extrusion multiplier 0.97
PLA
i have tried editting the settings but it doesnt make a difference
Posted: Fri Nov 27, 2015 6:26 pm
Not sure if you've seen this....but take a look at the section in the quality troubleshooting guide on blobs and zits. It should help you to understand what's going on...and give you clues on how to get rid of them!
https://www.simplify3d.com/support/prin ... s-and-zits
Posted: Sat Nov 28, 2015 3:06 am
by Tttugeman
I have looked at that already, i have even tried my coasting at end to 8mm and blobs are still occurring?
Posted: Sat Nov 28, 2015 4:19 am
by horst.w
Multiplier for PLA best +/- 0.90 when the real filament thickness is exactly given in OTHERS
Layer thickness? Nozzle width? Extrusion width? Retraction speed? Retraction lift? Nozzle temperature? Print speed?
Coast at end 0.08 are not 8 mm (8.00 mm)
The viscosity of molten PLA is very low (in contrast to ABS) and the fault may also be caused by the filament and / or mechanical problems.
It will be very helpfull when you attache the factory-file.
H.
Posted: Sat Nov 28, 2015 11:05 am
A second suggestion to allow you to get to the bottom of your blobs. Have a read of
jimc 's first reply in this thread:
viewtopic.php?f=9&t=3629 Particularly the bit about the difference between blobs at the end of a layer and blobs at the beginning of a layer....and the different means of addressing. Are your blobs from the start or the end of the layer?? Identify that first....then work on the cure.
Details of your factory file would also be useful for anyone trying to remotely resolve your issue for you.
