When using a raft, when I preview the first layer of the object (layer 6) and then move forward to the next layer (layer 7) it shows the base rectilinear fill at 45 and then the 7th layer is at the same z height with a follow up -45 fill with a narrower extrusion. Now this seems to make sense as it is attempting to really fill in that base layer as its underside has a larger gap making the first extrusion gaps larger. However when I then take this to my printer with a Ramps 1.4 controller running Marlin that 7th layer appears to print at the next layer thickness up (0.15mm in my case) rather than, as the preview suggests, the same height as layer 6. This is what the 6th and 7th layers look like in the preview -
The Gcode looks like this -
; layer 6, Z = 1.73204
M105
; tool H0.196 W0.360
; inner perimeter
G1 X83.919 Y109.563 F6000
G1 Z1.732 F3000
G1 E0.0000 F3000
G92 E0
G1 X61.081 Y109.563 E0.7182 F4500
; layer 7, Z = 1.71204
M105
; tool H0.150 W0.360
; inner perimeter
G1 X76.994 Y83.199 F6000
G1 Z1.712 F3000
G1 E0.0000 F3000
G92 E0
G1 X76.966 Y83.115 E0.0021 F4275
Notice here that the 7th layer actually lowers down a fraction from the previous layer to really flatten out that first "fat" layer?
Unfortunately it looks like the Marlin firmware detects this as a mistake in the Gcode and disallows the merging of the layers, resulting in the 7th layer just going over the top like a regular layer at the next height up.
I'm just about to go and run this code on the printer and will take a video/photos of it doing layer 6 and then 7 to show the result.
Back in a bit...
