yinzer
Min Layer Time and Extruder Speed Issue
Hello,
I am having problems with speed overrides and extruder correlation. I am trying to print a part at 30mm/s but some of the layers use the speed reduction cause they would be less than 10 seconds. Problem is the extruder RPM is remaining the same speed even when the head slows down. Anyone know about this bug? Using BFB 3d touch.
Thanks
Yinzer
BitHolder.txt.bfb.zip
gcode
(88.11 KiB) Downloaded 133 times
perohlsson
Re: Min Layer Time and Extruder Speed Issue
Hi Yinzer.
The main problem:
Postprocessor don't posting M108 Sxxx from slicing data. The filament speed (M108) is coming from the "Starting Script"
and keep the same speed thru the hole process. Not good. All nice features don't work for us with Simplify3D & BFB 3D Touch. :cry:
Have you solve the problem?
/Per
/Per
Printer 1: Flashforge Finder
Printer 2: BFB - 3D Touch
Slicer 1: Simplify 3D
Slicer 2: Flashprint
Solidworks 2014
