Different hotends on a dual setup?
Posted: Mon Nov 30, 2015 5:38 pm
by saramos
I have a Taz 5 with a single Hexagon 3mm hotend. I picked up a Hexagon 1.75 hotend with the intent of doing a conversion. But am now wondering if I could use both in a dual extruder setup with the S3D software, or if they have to be the same?
Scott
Re: Different hotends on a dual setup?
Posted: Tue Dec 01, 2015 5:17 am
by JoeJ
Yup, you can since they allow you to set a separate extrusion amount for each extruder. Read this:
viewtopic.php?f=8&t=3718#p16283
Posted: Wed Dec 09, 2015 7:17 am
I've use the method above and it works, although, you might want to get everything using the same filament size so you don't have to constantly keep both types in stock
