My first foray into designing a print - help!
Posted: Mon Nov 30, 2015 7:44 pm
by Zseng10
My apologies in advance if this is not the right place to post this question, or if this would be a better question for the SketchUp community.
Long story short, I am trying to design a part in sketchup. A little clip that has a void down the center of it. This open section is approximately 1.25mm wide by 12mm long. Everything looks good in sketchup, and it passes all tests in S3D's checks in the repair tab (Not bad for a first-ever design, I like to think).
The problem comes in when I go from the prep stages in S3D to preparing for a print, Looking at the preview, that empty space is filled in, creating a solid piece. I have attached screenshots from S3D, I would attach the sketchup file but it looks like .skp is not allowed on here.
Are there certain dimension tolerances that S3D cannot handle or will ignore and therefore fill in, or am I missing something else altogether.
Re: My first foray into designing a print - help!
Posted: Tue Dec 01, 2015 5:19 am
by JoeJ
It's hard to tell just by looking at it. Attach your factory file to this thread so that we can check it out (go to File > Save Factory File)
Posted: Tue Dec 01, 2015 8:01 pm
by RomeFallsAgain
Did you use a program like NetFabb to REPAIR the STL file ? If not, you may have holes in your design that affect the filling of it.
I ALWAYS use a program to check my designs for flaws. It often finds them and fixes them.
Posted: Wed Dec 02, 2015 12:33 am
by dsegel
Either there's a problem with the model, or you have the "Merge all outlines into a single solid model" option checked (it's on the Advanced tab in your process).
Posted: Thu Dec 03, 2015 2:18 am
by Viceman
Why don't you print it in different position? The round end to bottom?
