Extruder on DaVinci not centered
Posted: Wed Dec 02, 2015 6:55 am
The extruder on my printer is about 34mm offset to the right. It homes the X axis fine, but when moving the extruder to 100 on the x axis (200mm^2 print bed) it is slightly off to the right. Is there a way to manually change this? Larger prints fail because it will just extrude plastic over the right side of the bed, thinking it is centered. I flashed Repetier frimware to the printer so I can use filament that wasn't DRM locked by XYZ, so that is probably why the preset DaVinci profile didn't work.
