Lulzbot Mini - Cura vs Simplify3D
Posted: Thu Dec 03, 2015 10:39 pm
by Ursadorable
So I picked up Simplify 3D on recommendation of some forums and decided since I was printing some Mendel parts for a friend, I'd try both programs with the default Lulzbot Mini settings.
Here are my results, which I'm not really eager about.
Left: Cura Lulzbot Edition - ABS, High Quality
Right: Simplify3D (Lulzbot Mini Config) - ABS, High Quality
https://www.dropbox.com/s/h45zg4qo4as76 ... 5.jpg?dl=0
Re: Lulzbot Mini - Cura vs Simplify3D
Posted: Fri Dec 04, 2015 9:27 am
For S3D, I would recommend increasing the "outline overlap percentage" on the Infill tab. That will help close some of those tiny holes you are seeing. I would also add a few more top solid layers to help make that top section more solid.
Posted: Fri Dec 04, 2015 11:15 pm
by saramos
Also, I would check the option Allow gap fill when necessary on the Advanced tab.
I have the Kittaz upgraded to a Taz 5. I ran with Cura and Kiss for a long time. I picked up S3D a few weeks ago. After getting things dialed in, I find many of the advanced features (multiple processes per part, editing supports and others) indispensable. It's worth putting in time to learn S3D well. In the end, I think you will find it worth the cost.
