Erratic Retractions
Posted: Sun Dec 13, 2015 3:10 am
by Bking1340
Good day all
Have a problem with retraction. Speed are at 30mm/s at 1.5mm.
60% of the time the retraction are 1.5mm(as set in S3D) and sometime +- 5mm. I cant pinpoint where or why the 5mm retraction occur, because it`s at different places at different times.
The direct drive extruder motor are cold, voltage/amps are set correctly, tension between bearing and MK7 are correct, no strange clicking or weird noises from the extruder - so mechanically it seems fine.
Don`t know where to go and look for the problem - this is happening on all prints.
Re: Erratic Retractions
Posted: Sun Dec 13, 2015 8:12 am
by jimc
Yes there was a thread on this awhile back. There is a bug if some sort that has to do with the wipe feature. Cant remember if its having the wipe feature just turned on or the wipe while retract box checked.
Posted: Sun Dec 13, 2015 9:01 am
by Bking1340
I will try a print without wipe.
It`s definitely a setting, because I just did exactly the same print on Repetier host/sli3er and my retraction is 1.5mm as my settings with no +-5mm retraction.
