Lines on the Side of Print
Posted: Thu Dec 17, 2015 3:53 pm
by 3d-Druck-ingenieur
I'm trying to get good results with my mankati full scale plus and simplify3d.
But I always got those lines on the side of the print (every 4. layer):
I already tried:
-Different temperatures (nGen filament)
-Coast at End (1-2mm)
-Wipe Nozzle (1-2 mm)
-Force retraction between layers
-different filament
But with no success. The second cube was printed with MankatiUM with default profile, the result was not good but no lines.
Thanks for the help!
Re: Lines on the Side of Print
Posted: Fri Dec 18, 2015 5:50 am
Try grouping all your start points towards a specific location (see the Layer tab). That has helped me.
There's other suggestions for this issue here: https://www.simplify3d.com/support/prin ... e-of-print
Posted: Fri Dec 18, 2015 10:47 am
CompoundCarl wrote:Try grouping all your start points towards a specific location (see the Layer tab). That has helped me.
I will try changing the starting point.
For the troubleshooting guide:
- It cant be inconsistent extrusion because i changed the filament and i had the same problem
- It cant be temperature: because i changed the temperature and the temperature is stable
- It cant be mechanical: because with MankatiUM i don´t have this problem
Posted: Sat Dec 19, 2015 8:28 am
by martinkopplow
It looks like the infill pattern 'shines through'. Are you printing a solid infill layer each x layers? That could be responsible for the horizontal lines, if a thin wall is being used, say only one or two shells.
Posted: Sun Dec 27, 2015 9:45 am
martinkopplow wrote:It looks like the infill pattern 'shines through'. Are you printing a solid infill layer each x layers? That could be responsible for the horizontal lines, if a thin wall is being used, say only one or two shells.
No I don´t print a solid infill each x layers.
I couldn't find a solution but the problem doesn't occur when I use a small layer height (0,1). The Problem was only with 0,2 mm an not with 0,1 or 0,15 mm.
