Rebekah_harper
Random solid layer
hiya guys and gals.
I have a part that when I got to preview and analyse it I find a random unwanted solid layer.
I cant explain it and I have tried different things but I can't get rid of it.
You can see the bridging layer in side the cavity of the part.
I have attached the factory file.
please help.
many thanks
Becky
TEST MOLD.factory
factory file 0.2mm nozzle
(1.09 MiB) Downloaded 210 times
Re: Random solid layer
Hi Becky
Change your layer thickness to 0.1001 mm....and the problem will be solved!
This is a quirk of the slicer. If it encounters an issue in the mesh at exactly a layer boundary, things go screwy. Changing the layer thickness so the issue is missed cures it!
Rebekah_harper
that's brilliant,
thank you :)
Becky
