Position readout Blank
Posted: Mon Dec 21, 2015 2:43 pm
by p0lar
When I connect to my replicator 1 i dont get any position. I do get heat and control.
Thoughts?
Re: Position readout Blank
Posted: Tue Dec 22, 2015 5:54 am
Well, that's probably because the printer doesn't know it's position yet. What happens if you click "Home All" on the Jog Controls tab? At that point, the printer will go to it's known origin, so I would think it might update the position.
Anyways, it seems to work fine once your printing or moving around, so I wouldn't be alarmed if it shows 0,0,0 at the initial startup. Just home the axes if it really bothers you.
Posted: Mon Dec 28, 2015 8:54 pm
by p0lar
ok I think that is working now. good to know
Posted: Tue Dec 29, 2015 12:55 am
by p0lar
its still a bit wonky. when i move two 10 steps it shows 20 on the z x & y access. when I hit home all i get the below screen... not 0
Posted: Tue Dec 29, 2015 6:08 am
That's because the corner where your printer homes is not (0,0), so it should not say zero! It's working correctly as far as I can see
