That's what that's for! Very useful feature! I'm new to this software so some of it's features are still foreign to me. The issue with that feature is if you have a part that varies it's width greatly along it's axis you end up with floating support clouds where supports are created intra-model. Here's a test I did with overkill inflation distance to illustrate. Any way to get around that in the settings?CompoundCarl wrote:I love to use the "extra inflation distance" option on the Support tab for this. It widens the entire support structure to give it a larger base. Works really well for my prints where you have thin tower that may fall over otherwise.
This is a brilliant solution! I think I'll be using this approach for the time being.dkightley wrote:Here's how I would do it:
Create three sacrificial parts that I position just above the top of the cylinder, then add custom supports as shown... Change the support horizontal distance to 0.1mm, make the support angles 45, 45,-45,-45,45,45,-45,-45. The support will look like this: Very rigid...and won't let the cylinder go anywhere!
