Dual Extrusion Issue - Double Printing
Posted: Fri Dec 25, 2015 2:02 pm
by RomeFallsAgain
Merry Christmas!
I have a FlashForge Creator Pro Clone. For the most part it works great. But yesterday I began experimenting with the Dual Extrusion Wizard.
So far I have not been able to successfully print a build using it.
What's happening is that it is printing all the layers with both extruders.
The Print preview does NOT show this duplicity. In the Print preview it looks perfect.
Here's the beginning GCode
; G-Code generated by Simplify3D(R) Version 3.0.2
; Dec 25, 2015 at 10:11:16 AM
; Settings Summary
; processName,Color1
; applyToModels,1_P1CamProt_NOGPS_1P (repaired)
; profileName,FlashForge Creator Dual(2) (modified)
; profileVersion,2015-05-01 08:00:00
; baseProfile,
; printMaterial,PLA
; printQuality,High
; printExtruders,Both Extruders
; extruderName,Right Extruder,Left Extruder
; extruderToolheadNumber,0,1
; extruderDiameter,0.4,0.4
; extruderAutoWidth,0,0
; extruderWidth,0.4,0.4
; extrusionMultiplier,0.9,0.9
; extruderUseRetract,1,1
; extruderRetractionDistance,1,1
; extruderExtraRestartDistance,0,0
; extruderRetractionZLift,0,0
; extruderRetractionSpeed,1200,1200
; extruderUseCoasting,0,0
; extruderCoastingDistance,0.2,0.2
; extruderUseWipe,0,0
; extruderWipeDistance,5,5
; primaryExtruder,0
; layerHeight,0.1
; topSolidLayers,5
; bottomSolidLayers,5
; perimeterOutlines,2
; printPerimetersInsideOut,1
; startPointOption,2
; startPointOriginX,0
; startPointOriginY,0
; startPointOriginZ,300
; sequentialIslands,0
; spiralVaseMode,0
; firstLayerHeightPercentage,90
; firstLayerWidthPercentage,100
; firstLayerUnderspeed,0.2
; useRaft,0
; raftExtruder,0
; raftLayers,3
; raftOffset,3
; raftSeparationDistance,0.14
; raftInfill,85
; disableRaftBaseLayers,0
; useSkirt,0
; skirtExtruder,0
; skirtLayers,2
; skirtOutlines,2
; skirtOffset,4
; usePrimePillar,0
; primePillarExtruder,999
; primePillarWidth,12
; primePillarLocation,7
; primePillarSpeedMultiplier,1
; useOozeShield,0
; oozeShieldExtruder,999
; oozeShieldOffset,2
; oozeShieldOutlines,1
; oozeShieldSidewallShape,1
; oozeShieldSidewallAngle,30
; oozeShieldSpeedMultiplier,1
; infillExtruder,0
; internalInfillPattern,Rectilinear
; externalInfillPattern,Rectilinear
; infillPercentage,30
; outlineOverlapPercentage,20
; infillExtrusionWidthPercentage,100
; minInfillLength,5
; infillLayerInterval,1
; infillAngles,45,-45
; overlapInfillAngles,0
; generateSupport,0
; supportExtruder,0
; supportInfillPercentage,40
; supportExtraInflation,0
; denseSupportLayers,0
; denseSupportInfillPercentage,70
; supportLayerInterval,1
; supportHorizontalPartOffset,0.3
; supportUpperSeparationLayers,1
; supportLowerSeparationLayers,1
; supportType,0
; supportGridSpacing,4
; maxOverhangAngle,45
; supportAngles,0
; temperatureName,Right Extruder,Left Extruder,Heated Build Platform
; temperatureNumber,0,1,0
; temperatureSetpointCount,1,1,1
; temperatureSetpointLayers,1,1,1
; temperatureSetpointTemperatures,190,190,60
; temperatureStabilizeAtStartup,0,0,0
; temperatureHeatedBed,0,0,1
; temperatureRelayBetweenLayers,0,0,0
; temperatureRelayBetweenLoops,0,0,0
; fanLayers,1,2
; fanSpeeds,20,100
; blipFanToFullPower,0
; adjustSpeedForCooling,1
; minSpeedLayerTime,15
; minCoolingSpeedSlowdown,20
; increaseFanForCooling,0
; minFanLayerTime,45
; maxCoolingFanSpeed,100
; increaseFanForBridging,1
; bridgingFanSpeed,100
; use5D,1
; relativeEdistances,1
; allowEaxisZeroing,0
; independentExtruderAxes,1
; includeM10123,0
; stickySupport,1
; applyToolheadOffsets,0
; gcodeXoffset,0
; gcodeYoffset,0
; gcodeZoffset,0
; overrideMachineDefinition,1
; machineTypeOverride,0
; strokeXoverride,220
; strokeYoverride,140
; strokeZoverride,150
; originOffsetXoverride,110
; originOffsetYoverride,70
; originOffsetZoverride,0
; homeXdirOverride,1
; homeYdirOverride,1
; homeZdirOverride,-1
; flipXoverride,1
; flipYoverride,-1
; flipZoverride,1
; toolheadOffsets,0,0|34,0|0,0|0,0|0,0|0,0
; overrideFirmwareConfiguration,1
; firmwareTypeOverride,MakerBot/Sailfish Firmware
; GPXconfigOverride,r1d
; baudRateOverride,115200
; overridePrinterModels,1
; printerModelsOverride,MakerBot_Replicator1.stl
; startingGcode,; **** Replicator 1 dual start.gcode ****,M73 P0 ; Enable build progress,G162 X Y F3000 ; Home XY maximum,G161 Z F1200 ; Home Z minimum,G92 Z-5 ; Set Z to -5,G1 Z0 ; Move Z to 0,G161 Z F100 ; Home Z slowly,M132 X Y Z A B ; Recall home offsets,M135 T0 ; Load right extruder offsets,G1 X-120 Y-70 Z30 F9000 ; Move to wait position off table,G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating,M126 S[fan_speed_pwm] ; Set fan speed,M140 S[bed0_temperature] T0 ; Heat buildplate ,M134 T0 ; Stabilize bed temperature,M104 S[extruder0_temperature] T0 ; Heat right extruder,M104 S[extruder1_temperature] T1 ; Heat left extruder,M133 T0 ; Stabilize right extruder temperature,M133 T1 ; Stabilize left extruder temperature,G130 X127 Y127 Z40 A127 B127 ; Default stepper Vrefs,G92 A0 B0 ; Zero extruders,G1 X100 Y-73 F9000 ; Move to front right corner of bed,G1 Z0.3 F6000 ; Move down to purge,G1 X-90 Y-73 E24 F2000 ; Extrude a line of filament across the front edge of the bed,G1 X-100 Y-73 F180 ; Wait for ooze,G1 X-110 Y-73 F5000 ; Fast wipe,G1 Z0.5 F100 ; Lift,G92 A0 B0 ; Zero extruders,M135 T1 ; Load left extruder offsets,G1 X-100 Y-68 F9000 ; Move to front left corner of bed,G1 Z0.3 F6000 ; Move down to purge,G1 X90 Y-68 E24 F2000 ; Extrude a line of filament across the front edge of the bed,G1 X100 Y-68 F180 ; Wait for ooze,G1 X110 Y-68 F5000 ; Fast wipe,G1 Z1 F100 ; Lift,G92 A0 B0 ; Zero extruders,M73 P1 ;@body (notify GPX body has started),; **** end of start.gcode ****
; layerChangeGcode,
; retractionGcode,
; toolChangeGcode,
; endingGcode,; **** Replicator 1 dual end.gcode ****,M73 P100 ; end build progress,G1 Z150 F1000 ; send Z axis to bottom of machine,M140 S0 T0 ; cool down HBP,M104 S0 T0 ; cool down right extruder,M104 S0 T1 ; cool down left extruder,M127 ; stop blower fan,G162 X Y F3000 ; home XY maximum,M18 ; disable stepper,M72 P1 ; play Ta-Da song,; **** end of end.gcode ****
; createX3G,1
; celebration,0
; celebrationSong,Random Song
; createMB5G,0
; postProcessing,
; defaultSpeed,2600
; outlineUnderspeed,0.5
; solidInfillUnderspeed,0.8
; supportUnderspeed,0.8
; rapidXYspeed,2600
; rapidZspeed,1200
; minBridgingArea,50
; bridgingExtraInflation,0
; bridgingExtrusionMultiplier,1
; bridgingSpeedMultiplier,0.8
; filamentDiameter,1.75
; filamentPricePerKg,46
; filamentDensity,1.25
; useMinPrintHeight,0
; minPrintHeight,0
; useMaxPrintHeight,0
; maxPrintHeight,0
; useDiaphragm,0
; diaphragmLayerInterval,20
; robustSlicing,1
; mergeAllIntoSolid,0
; onlyRetractWhenCrossingOutline,1
; retractBetweenLayers,1
; useRetractionMinTravel,0
; retractionMinTravel,3
; retractWhileWiping,0
; onlyWipeOutlines,1
; avoidCrossingOutline,0
; maxMovementDetourFactor,3
; toolChangeRetractionDistance,12
; toolChangeExtraRestartDistance,-0.5
; toolChangeRetractionSpeed,600
; allowThinWallGapFill,1
; thinWallAllowedOverlapPercentage,10
; horizontalSizeCompensation,0
G90
M83
G1 Z0 ; Move Z to 0
M126 S51 ; Set fan speed
M140 S60 T0 ; Heat buildplate
M104 S190 T0 ; Heat right extruder
M104 S190 T1 ; Heat left extruder
G1 Z0.5 F100 ; Lift
G1 Z1 F100 ; Lift
G1 E-1.0000 F1200
G1 Z0.090 F1200
; layer 1, Z = 0.09
M135 T0
; tool H0.100 W0.400
; inner perimeter
Re: Dual Extrusion Issue - Double Printing
Posted: Sat Dec 26, 2015 5:50 am
Are you sure it isn't just the second extruder leaking? Post your factory file so we can check your settings (file > save factory file).
FYI - I run dual extrusion on the FFCP all the time and it works great using their stock profile with the dual extrusion wizard
Posted: Sat Dec 26, 2015 8:56 am
by RomeFallsAgain
CompoundCarl wrote:Are you sure it isn't just the second extruder leaking? Post your factory file so we can check your settings (file > save factory file).
Hello Carl,
Is there a test I can run to ensure my left extruder isn't leaking?
The "ghost" print coming from the inactive extruder (left) is fully extruded and doesn't appear to be a minor leak.
Could it be leaking enough to perfectly print that ghost print?
I've had that suspicion for a while even though I can successfully print items with just that extruder.
Posted: Sun Dec 27, 2015 8:27 am
Easy test would be to post a picture of your print after about 20 or so layers. It would be easy to tell from the photo.
Alternatively, just watch the drive gear of your second extruder. Is it actually spinning when you think it should be inactive? Or is it just idle, but there is still a tiny amount of plastic coming out?
