Hi , may I can use different settings for the top and bottom layer ? How to do this ? I mean I wish I can set different last layer above the top layer , not just the top that ends the piece to print it when the top layer is placed at different levels, thanks in advance .
Hello
I would like bottom layer to print them at high speed , and the top layer low speed without making multiple processes for the same song , I did this but only for the final coat , I find it very difficult to do that if I have a track the top floor has several layers , and from what I saw can not use different settings for bottom and top speed layer
For instance what speed settings for the top layer using ?
You can adjust the "solid infill underspeed" setting on the Other tab. That will decrease the speed for the top and bottom solid layers. I use this a lot and it works great and definitely improves the print quality
