Qidi Tech I Dual Extruder - Print Profile Issues
Posted: Fri Jan 01, 2016 6:20 pm
I recently received this Qidi Tech Dual Extruder printer from Amazon:
http://www.amazon.com/gp/product/B00SB6 ... 1_1&sr=8-1
In the reviews people mentioned that Simplify3D was the way to go for software using the Flashforge Creator Pro profile. When i chose this profile and start the bed leveling wizard it lined up my right extruder of of the edge of the build platform only on the right side, when it jogged over to the left side it seemed that it was more middle of the platform rather than left.
I decided to see what would happen if I tried to print and sure enough, the right extruder lined up about a quarter inch to the right of the platform and started spewing filament into empty space. After this it jogged to the middle of the build platform and tried to print. First off the extruder seemed to be scraping the bed so any filament that was able to squeeze though was a stringy mess. Secondly, the speed seemed to be way too fast and was apparently ignoring the 50% speed reduction for the first layer in the print profile. I changed the extrusion multiplier down from .9 to .1 which changed nothing really. Is this the same feed rate? Either way it seems this profile was not meant for this printer. I also verified that the bed size was set correctly to 230x150x150mm in the machine settings.
Now the strange thing is other people have commented that this is the profile they use and have no issue. It does seem that these folks have an older model printer though. This is a complete rip off of the Flashforge Creator Pro and has the exact same dimensions and parts used so it is made to work with the same profile settings.
I'm wondering if anyone has ordered this printer in the last month and successfully had it work with Simplify3D or not? If not, can anyone offer suggestions? I've tried various print profiles as well, none of which worked. I verified that the printer was functioning correctly by trying the ReplicatorG software that came with it and it printed out some calibration cubes perfectly so I know this is purely a software issue.
