Feature Requests: More precision on Retract. Vert. Lift
Posted: Sat Jan 02, 2016 2:52 pm
I would need one more digit of precision on the Retraction Vertical Lift.
Probably an easy thing to do for you
It seems a weird request , But My vertical axes treaded rod are in imperial values. Asking multiples of 0.254 give-out better result in the rod positioning when going back and forth with the motors. I use this trick in cura before with good improvements.
All of you guys with the metric system are so lucky !
