Having an issue with the Dual Extrusion Wizard
Posted: Mon Jan 11, 2016 11:57 am
I have two separate STLs, one is flat rectangle about 5mm thick and the other STL is lettering that is also 5mm thick and I have it so that the letters are centered on the rectangle in 123D Design.
When I run the Dual Wizard everything looks ok, but if I step through the print Layer by Layer I notice that the lettering is being overwritten by the other extruder every couple layers. It will create a layer of the letters then the rectangle extruder will fill in the whole object for a layer then it goes back and forth like this.
I assumed the extruder that is doing the rectangle STL would lay down filament only around the letters. Am I incorrect in thinking this?
Thanks for any help
Thanks for any help
