Pathing question with Dual Extrusion
Posted: Fri Jan 15, 2016 11:03 pm
What I have is an iPhone case that I have some lettering and logo in the back of it that I am dual printing. Initially I had the thickness of the lettering and logo geometry at 1.75mm and the back of the case is 2mm. I realized that there was no need for that extra thickness on the lettering and logo and took it down to .8mm as I am doing .2mm layers.
I assumed that by doing this my print time would decrease as it wasn't having to do all those layers of intricate lettering, but what I see when I slice it and then look through layer by layer is that is does 4 layers of the lettering in the extruder I set to that stl but then it goes to the other extruder but continues to trace out and fill in the letters with the other extruder as if it was still there. I assumed it would switch to to my infill setting which is 30% and that would speed up the print.
Why do you think it slices the model this way even though the lettering stl is only .8mm of the overall 2mm? I have top and bottom solid layers set to 3, but it does the lettering at 100% infill until the last 3 layers and then it stops tracing out the lettering and logo.
Thanks,
Chris
Thanks,
Chris
