Set Z Height After Home
Posted: Mon Jan 18, 2016 7:36 pm
by Nick7875
I'm looking for a way to set my Z height after I home my machine, I need a way to fine tune it. I have a prusa i3 with the end stop clamped on the guide bar so adjustments up and down are guess work at best. thanks for any help. Hope its just a setting i missed.
Re: Set Z Height After Home
Posted: Tue Jan 19, 2016 7:33 am
You can use the global Z-axis gcode offset in S3D to easily compensate for the bed positioning. It's on the G-Code tab.
For example, entering 0.1mm for the Z-axis offset will shift the nozzle 0.1mm further away from the bed for the entire print
